m112 adapter help
mysteed is a member here an over on V6power.net. His name is Nathan. Send him a message here as well as over there and he should be able to sell you the kit. It costs $3,000. You can also message NYstang here (alex) and he can contact Nathan directly for you because I believe they work together and Alex is on here much more often than Nathan. Do you know anything about the kit? What else you will need? Have you read the sticky? Do you know a good dyno tune shop?
keep in mind that the adaptor is all hand made, so the price is expensive. when its welded together, it has to be carefully done so taht the top plate doesnt warp. Ive seen it happen many times, and nathan had a batch of plates have the happen,iirc.
the kit is 3k + shipping. it includes EVERYTHING to install it(plate, M112, injectors, fuel pump, instructions), but it is reccomended that you buy-
1- an underdrive pulley. this brings the boost down a bit, and keeps heat manageable.
2- boost guage
3- tune. this is REQUIRED. VMPperformance has a mail order tune and datalogging you can do for 250, but a better choice would be a dynotune.
seeing as you are in NY, I would suggest MustangMagic down on long island.
2- boost guage
2- boost guage
2- boost guage
