windstar intake??
im trying to look more in to the windstar intake, is it worth doing if i use the stock MAF and a K&N intake with a 65 mm bbk throttle body ?? and if anybody can give me more info on the windstar intake i would appreciate it thanks
K&N intake system will not work, but any any cone filter with a 3" opening will. I'm running stock MAF, as are most people that I know who run the windstar upper. It's worth doing but the instructions provided with the VAP kit are very confusing if it's the first time installing it. But after you install it a couple of times it's very easy to install. If you haven't deleted your EGR yet I would strongly recommend doing so with the windstar install, as it will really help clean up some of the clutter in the engine bay. The throttle body should work fine, it may cause the throttle cable geometry to be a bit off but should still work perfectly fine, just be sure to get new gaskets bc you will have gasket leaks after doing the install and you don't wanna be taking this stuff apart and having to do it multiple times only to find out your leak was from a damn gasket.
I've done the install a few times so if you have any questions feel free to PM me.
It might show me as being on 24/7 but I'm really not, I just leave my computer on 24/7 and rarely shut it down so if I don't respond quickly, it's not because I'm ignoring you.
Yes it is a nice change to have, I did it myself and love it. If you decide to delete your egr is the only time you will need a tuner. If you are not willing to do that just get a coinciding year egr mount tube and it will drop it low enough to mount. The install is very simple just have you use your brain for the most part.
