Rough feeling underneath
Old Mar 8, 2010 | 03:32 PM
Muh Stang's Avatar
Muh Stang
Default Rough feeling underneath
I bought my 99 last week knowing there were a few problems we could fix. There was some mean howling coming from the rear end around 40mph so we had to replace the rear dif. The howling stopped, after we replaced it, but we found out some new stuff in the process. We think either the drive shaft is out of round, and I also need to replace the filter in the transmission, or something is loose in the rear house of the transmission were the drive shaft goes in. You can feel rumbling in the seat at certain points while raising speed. When it goes to shift into another gear (automatic btw) it is very smooth. It also takes a few seconds to shift into drive / reverse. If anyone can give some ideas as to what it might be I would appreciate it greatly.
Old Mar 8, 2010 | 05:13 PM
TurtleSLow's Avatar
TurtleSLow
make sure the bolts that hold the driveshaft to the pinion on the rear end are tight, sometimes they come loose after reinstallation if not tight enough, that could be the rumbling.
Old Mar 8, 2010 | 05:36 PM
neo8222's Avatar
neo8222
yeah once i got under there again and checked after i put my driveshaft back in and found they were loose enough to spin by finger... LOKTITE!!
Old Mar 9, 2010 | 01:48 AM
NeoTokyo's Avatar
NeoTokyo
Could always do a 5spd swap, that way you know exactly how everything went back together and arent worried about someone elses handy hack jobs.
Congrats on the new car too, its kinda like a mino resto but without rust to deal with like classics.
Old Mar 9, 2010 | 12:17 PM
Muh Stang's Avatar
Muh Stang
Thanks for the suggestions. Bolts and all are still tight.. Still making a rumbling. Maybe I need to get the Drive shaft rebalanced?
Old Mar 9, 2010 | 10:58 PM
TurtleSLow's Avatar
TurtleSLow
it may have been put back on wrong, your supposed to mark where it was lined up to the pinion, and reinstall to the mark, but i totally forgot to do that when i had mine off a few times and i never got a rumbling. not sure if that would be your problem. i dont see how the driveshaft could have came unbalanced itself tho
Old Mar 10, 2010 | 12:58 AM
NeoTokyo's Avatar
NeoTokyo
Could always grab an aluminum DS and see if that helps, if it doesnt at least its an upgrade and you can move on to the next part that might be doing it.
Old Mar 10, 2010 | 01:10 PM
Muh Stang's Avatar
Muh Stang
Well I got some advice from a mechanic. He said most likely the person who owned it before me rode it hard and stomped on it from a dig and that could have thrown the DS out of balance. Now I need to find a shop that can test the theory...
Old Mar 10, 2010 | 04:56 PM
TurtleSLow's Avatar
TurtleSLow
a stock v6 mustang doesnt have enough power to mess with the driveshaft when "stomping on it from a dig", plus the wheel would have just lost traction
Old Mar 17, 2010 | 01:43 PM
Muh Stang's Avatar
Muh Stang
Changed the filter and replaced a bad bushing in the tranny and now shes running nice and shifting into gear smoothly. Yay
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
