pushrod length? lifters?
Old Apr 13, 2010 | 12:01 AM
Cryptostorm's Avatar
Cryptostorm
Default pushrod length? lifters?
so i have ssm stage 2+ heads and a comp cam 903 cam...
i get it all together, and some of the rockers have perfect lash, some of them are just at 0 lash, and some of them are loosey goosey.. so i get a oil pump priming tool, and prime the pump and turn the engine by hand until i get oil out the end of the pushrods..
as of right now there are 2 rockers that aren't even to zero lash..
I was always under the impression that all of your pushrods should all be the same length.. but with these engines having non adjustable rocker arms maybe that isn't the case???
my only other thought was that maybe i need a few new lifters?? (not priming correctly)
any thoughts on the subject?
Old Apr 13, 2010 | 11:01 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The lifters are pretty cheap, I'd go ahead and get them, and get a push rod length checker to make sure you get the right stuff.
Old Apr 13, 2010 | 11:17 AM
Cryptostorm
i'll get new lifters and see if that helps.. i ordered a pushrod length checker yesterday..
if the lifters dont take care of the problem, is the only way to change the pre load per lifter is the length of the pushrod? (IE up to 12 different length pushrods)?
Old Apr 13, 2010 | 02:30 PM
RyansQuick6
Reverse Gear Member
Uuuuuhhhhhhh, not sure, haven't had that issue yet lol
Old Apr 17, 2010 | 01:04 PM
Cryptostorm
hey ryan, do you know what the range of acceptable crush is on our lifters? to determine pushrod length..
I changed my lifters and it tightened it up, but only to zero lash..
Old Apr 17, 2010 | 09:56 PM
RyansQuick6
Reverse Gear Member
I have spent the past hour digging through all of my Ford manuals, and they say nothing, but that's because in their eyes, and most cam manufacturers, if it's stock, don't worry about it, just replace the parts with the same stock part.
What length checker did you get? The Comp Cams one is really good, you can actually check your preload with it to insure proper fit.
I want to say the "crush" to be in the range of .020 and .060, it seems every cam company agrees with that. if you REALLY want to fine tune it, do some more research and see what end of that +/-.040 range you want to be in.
Old Apr 18, 2010 | 05:37 AM
Detailer_Dave's Avatar
Detailer_Dave
If you want to be accurate, measure the travel distance of the plunger in the lifter. Divide in half to obtain 1/2 travel distance number. Adjust valve on cam base circle to zero lash, with adjustable pushrod, measure pushrod length, and add 1/2 plunger travel distance to obtain needed pushrod length.
Old Apr 20, 2010 | 10:44 PM
Cryptostorm
I did the same thing ryan; looked and looked and looked... it says what the 4.6 should be, but not the 3.8.. comp cams had a number on their paperwork, but i cant find it..
seems like .020-.060 sounds about right...
half crush would be like .180 and there is no way thats right..
Old Apr 21, 2010 | 01:39 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
I'm curious what is this 903 cam?
69Volunteer
Sep 30, 2015 10:39 AM
junior04
Sep 28, 2015 10:53 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
S'PortMustang69
Aug 30, 2015 08:27 PM
WDScott
Aug 17, 2015 06:38 AM
