1999 split port mods?
Old Apr 14, 2010 | 01:08 PM
kingjohn1027's Avatar
kingjohn1027
Lightbulb 1999 split port mods?
i am curious if there are any mods for the split port intake system? i understand that one port gives air at certain rpms/load and the other is opened at higher rpms...is there a way to have the secondary port open all the time? or would it hurt my performance? any info would be greatly appreciated
Old Apr 14, 2010 | 01:40 PM
Shaunmac9128's Avatar
Shaunmac9128
You can swap the split port upper intake manifold of the windstar which flows runners. I don't think your idea would be any good, no offense. Check vapauto.com for the kit and info about it.
Old Apr 14, 2010 | 01:54 PM
brent4's Avatar
brent4
x2 with what Shaun said. if you dont want to go the windstar and you dont want to get your upper and lower ported then vapauto sells a upper intake gasket that is supposed to give a bump in performance.
Old Apr 14, 2010 | 02:04 PM
kingjohn1027
thanks for the info! i think ill try swapping the upper and see how that goes. ill let you know how it turns out! thanks again!
Old Apr 14, 2010 | 02:27 PM
brent4's Avatar
brent4
iirc you will need a tune to go along with the windstar intake. as far as a tuner get one from vmptuning.com
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
