4.2 crank swap
Old May 12, 2010 | 11:31 PM
xToPPxDoGGx's Avatar
xToPPxDoGGx
Default 4.2 crank swap
are there any links on doing a 4.2 crank swap or can u tell me somethings about ? like if i do it will it lose the ability to be a daily driver and will it eat up gas like crazy? or any other good info on this ? thanks
Old May 13, 2010 | 09:23 AM
Shaunmac9128's Avatar
Shaunmac9128
It can still be a dd but I'm not sure about gas mileage, I doubt it would drop significantly if at all. It'll give you something like 5hp and 10-15tq over your stock 3.8 I believe. Its not just the crank though, you need the rod and probably pistons as well.
Old May 13, 2010 | 10:00 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The rods are the same.
Old May 13, 2010 | 10:12 AM
Shaunmac9128
I stand corrected. So you can just find a 4.2 crank and have a shop put your rods and pistons on it and your good to go?
Old May 13, 2010 | 12:47 PM
RyansQuick6
Reverse Gear Member
yup, of course the bearings and stuff, like any crank install, but nothing out of the ordinary.
Old May 13, 2010 | 03:11 PM
Grumio's Avatar
Grumio
you do need new 4.2L pistons tho, right? I thought you needed a 4.2 crank and pistons but could use the same rods. I could be wrong tho.
Old May 13, 2010 | 06:10 PM
rfcsoulja's Avatar
rfcsoulja
Is the 4.2 with stock pistons and rods stronger than our stock setup?
Old May 13, 2010 | 06:24 PM
RyansQuick6
Reverse Gear Member
All you need is the crank, that's it. I wouldn't say it's any stronger, I haven't seen any evidence to suggest that, but it's not weaker either.
Old May 13, 2010 | 06:30 PM
rfcsoulja's Avatar
rfcsoulja
So. . . .Would you say installing the 4.2 is worth the work?
Old May 13, 2010 | 06:40 PM
Grumio's Avatar
Grumio
Are you sure? I personally have no idea but this thread contradicts what you said.
http://www.3.8mustang.com/forum/show....php?p=3279481
It says that you need new pistons as well...
