Wheel Mounted Controls
Old May 19, 2010 | 09:00 AM
compdude97's Avatar
compdude97
Default Wheel Mounted Controls
Ok, What I want to do is relocate the on/off switch for the cruise and put in wheel mounted radio controls. I have a 97. Did any years with the same style wheel come with radio controls? Could I buy a wheel from a new mustang and install that or have the cruise control connections changed?
Old May 19, 2010 | 11:02 AM
neo8222's Avatar
neo8222
unless you REALLY know what your doing it wont work at all. the radio in the mustang was not designed to have external controls so
1 you must relocate cruise control by hand and custom wire new switches
2 you must remove radio, disassemble it and solder in wires to every control you want to has use of
3 you must find a radio control set that fits the steering wheel (probably has to be custom again)
it's a big job and not easy if you REALLY want to do it though it technically "can" be done but it will take a lot of knowledge.
Old May 19, 2010 | 11:07 AM
compdude97's Avatar
compdude97
Relocating the Cruise isn't a big deal I know I can do that. The radio I have is aftermarket that can accept the controls, so again no problem.
Finding something that would fit and look right is my concern.
Old May 19, 2010 | 11:27 AM
neo8222's Avatar
neo8222
ok then sounds like you got a good start at it then, i would suggest getting a "pin out diagram" from the manufacturer of your radio so you know what the wires on the remote control connector are for and what they do.
i would say the best option would be to get a steering wheel from a new mustang with all the controls on it and use that. im not positive how it would look in a new edge though.
Old May 19, 2010 | 11:56 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
You can only run 4 wires through your clockspring, and I think radio controls require more than that. Just make sure you don't accidentally catch an airbag wire.
FivePointToTheOh
Sep 14, 2015 03:35 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
