Engine question
Old May 27, 2010 | 10:21 PM
Kaleb's Avatar
Kaleb
Default Engine question
What I need to know is other than changing the liquids and stuff...This engine has not ran in about 2 years. Do you think it would run again or not even chance it and do an engine swap? I Think it would but this is why im here. What would keep it from running?
Old May 27, 2010 | 10:45 PM
socalwrench's Avatar
socalwrench
I would recommend priming the oil system before cranking it over. The only thing that I can think of being damaged from sitting would be some of the valvesprings- the ones that were compressed for 2 years.
Old May 27, 2010 | 11:07 PM
Fink's Avatar
Fink
the only way you can find out if it will run again is try and crank it over. Or you can get a socket and breaker bar on the crank pulley and try to see if the engine is seized. If its not seized then it should run if you have spark,fuel and air going into the engine.
Old May 28, 2010 | 09:21 AM
Kaleb's Avatar
Kaleb
Thanks, I did not think of this...a little old school but it works. I should have been doing this long ago to keep the pressure changing. Now what about freeze plugs?
Old May 28, 2010 | 10:01 AM
neo8222's Avatar
neo8222
unless you didn't have anti freeze in the car and the weather went under freezing point the freeze plugs should be fine you'll find out fast though if they aren't lol
Old May 28, 2010 | 10:20 AM
mustangted's Avatar
mustangted
i have stored cars much longer than that, change oil and drain the gas.
Old May 28, 2010 | 04:15 PM
Kaleb's Avatar
Kaleb
What about the other fluids? I did have antifreeze in there had just changed it out because of the thermostat. Luckly It was out of gas lol I want to change the fuel pump while its down...the whole reason it was down anyway becuase one carrier bolt and sheared off and the rear end started popping Im hoping to get an 8.8
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
