Susp Lowering Mod
Old May 29, 2010 | 10:45 AM
XtremeOracing's Avatar
XtremeOracing
Default Susp Lowering Mod
I am getting ready to do a suspension mod. I am installing new shocks and cutting 1 coil all the way around.
What would be the approx. expected drop from this?
Old May 29, 2010 | 10:55 AM
Shaunmac9128's Avatar
Shaunmac9128
about an inch, maybe a little over if I'm not mistaken.
Old May 29, 2010 | 11:40 AM
socalwrench's Avatar
socalwrench
Cutting one entire coil will usually lower the car more than the distance you're removing, because of the static corner weight on the spring (installed). I would try a half a coil, and remember to use a cut-off wheel.
Also, make sure the ends of the springs will fit back into their perches when you're done. Post pics when you're done.
Old May 29, 2010 | 12:03 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
look in the "how-to" sticky, i wrote a very big article on it.
Old May 29, 2010 | 02:10 PM
Shaunmac9128
Yeah read Ryan's sticky. I think he said 3/4 coil equals about an inch. So maybe start with that.
Old May 29, 2010 | 03:57 PM
XtremeOracing
Thanks for the heads up guys. I am going to do 3/4" and see how it sits. If i want lower i guess ill take the extra 1/4" out. I will post some before and after pics in a few when im done!
Old May 29, 2010 | 04:10 PM
XtremeOracing
just took a look at my brakes and i need to get them changed; so i am going to hold off on this until next weekend.
I am going to get some drilled, slotted rotors and brake pads and do it all at once!
Old May 29, 2010 | 05:00 PM
aaron187's Avatar
aaron187
Yea i'm gonna do the same to my car. i'm tired of the cruddy 4x4 stance
Old May 29, 2010 | 09:58 PM
RyansQuick6
Reverse Gear Member
Do either drilled OR slotted, only do both for pretty. I have both, cuz i like being pretty lol
Old May 30, 2010 | 08:41 AM
LilRoush's Avatar
LilRoush
Such a sig worthy quote.
