so lost steering noise
Old 05-28-2010, 08:07 PM
haystackstang
haystackstang's Avatar
Angry so lost steering noise
when i turn the wheel past a certain point either way makes a pop noise but when i jacked it up and turned nothing what could it be?
haystackstang is offline
Old 05-28-2010, 08:42 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Its that the ball joints? I have the same issue, plus very heavy vibrations from the brake pedal when braking....
Matthew
Matt's 95 Stang is offline
Old 05-29-2010, 12:53 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
balljoint or tie rod end.
RyansQuick6 is offline
Old 05-29-2010, 11:04 AM
Dub9Stang
Dub9Stang's Avatar
i had the same problem. grab where the tie rod end goes into the boot of the rack and pinion and wiggle it, make sure its not loose. Mine was, and thats where my problem came from.
Dub9Stang is offline
Old 05-30-2010, 04:16 PM
haystackstang
Ball joints are brand new and a arm so I'm assuming inner tie rod ?
Old 05-30-2010, 04:34 PM
RyansQuick6
Reverse Gear Member
inner or outer
Old 05-30-2010, 09:16 PM
945LSTANG
945LSTANG's Avatar
Originally Posted by RyansQuick6
inner or outer
+1
i had the same exact pop that got progressively worse. it was the tie-rod.
mine was even leaking a bit of grease.
945LSTANG is offline
Old 05-31-2010, 11:30 AM
haystackstang
Thank you guys for the help now if possible could some one tell me how to identify whether it's my inner or outter thank you
Old 06-01-2010, 02:09 PM
945LSTANG
945LSTANG's Avatar
mine was the outer.
Old 06-02-2010, 12:06 AM
haystackstang
I got that down how do I tell which one is bad loose etc
Quick Reply: so lost steering noise
