First Mods Plan
Old 07-03-2010, 07:37 PM
Future4.3LStang
Future4.3LStang's Avatar
Default First Mods Plan
Okay tell me what you think.
-Mac CAI
-Mac Long Tubes
-Mac H Pipe
-Mac Dual Exhaust
-NX Proton Kit(Run a 50 shot for now)
-Purge
-Bottle Heater
-Chepo Nitrous Pressure Gauge
-Comp Cams(Stage 1 Nitrous Cams)
-03/04 Cobra Front Bumper
-Blacked out heads and tails
-Black Out Panel
-Black 8" Antenna
-Black License Plate Surround
-Paint some interior pieces.
I already got a set of Black Saleen Wheels with Nitto 555R's
I can get everything except the Nitrous Kit for now.
Any suggestions?
Future4.3LStang is offline
Old 07-03-2010, 08:28 PM
jthorn9
The Godfather
jthorn9's Avatar
-Mac CAI
-Mac Long Tubes
-Mac H Pipe
-Mac Dual Exhaust.....sounds like complete crap
-Purge
-Bottle Heater
-Chepo Nitrous Pressure Gauge.....wouldn't cut corners with a gauge
-Comp Cams(Stage 1 Nitrous Cams)...comp makes cams for V6s???
-Black Out Panel
-Black 8" Antenna...be warned, some shorty antennas cause signal loss, not all but some
-Paint some interior pieces.....looks like crap IMO, and most Mustangers/true car enthusiasts
Any suggestions?
Get 3.73 or 4.10 gears and a limited slip differential.
Get an SCT tuner, will really come in handy with running the N2O safely.
jthorn9 is offline
Old 07-03-2010, 08:37 PM
Future4.3LStang
I thought you couldn't get either 4.10's or 3.73's in a 7.5inch Rear End? Anyways I forgot to add those.
Old 07-03-2010, 09:06 PM
Daehawk
Daehawk's Avatar
I agree with most of the stuff...cause i got that too lol. I'm not sold on those decklids though.
Daehawk is offline
Old 07-03-2010, 09:08 PM
Future4.3LStang
Do you have an Exhaust Clip?I would love to hear what it sounds like!
Old 07-04-2010, 01:08 AM
97camastang03
97camastang03's Avatar
Pretty good mod list. this will help from your first mod to your last.
Stage 1
Dual Exhaust (2.25" for Naturally Aspirated Cars and 2.5" for Blown Cars and some big NA strokers)
Rear End Gears & Traction-Lok (3.73 for Manual & 4.10 for Automatic)
Cold Air Intake
Underdrive Pullies
Short Throw Shifter (5-Speed) or Shift Kit (Automatic)
Stage 2
Torque Converter (Automatics)
Suspension Upgrade (Lowering Springs, Shocks & Struts, Rear Sway Bar and Strut Tower Brace).
Throttle Body (94-98) with crossover tube matching.
Custom Burned Chip, but most do not need this until Stage 3.
Stage 3
Ported and Polished Upper Intake, Lower Intake & Heads
Custom Ground Camshaft
Pushrods and Springs
Ignition System (Only needed if Forced Induction or Nitrous is used)
Fuel System Upgrades (190/255 lph fuel pump, bigger injectors & adjustable fuel pressure regulator)
Custom Chip necessary at this level for max power! Usually worth at least 10-15 RWHP and mucho low end torque.
Stage 4
Built 3.8 or 4.2L Engine (big bore best )
Supercharger, Turbocharger, Nitrous
Forged Internals (sic) Forged rods and pistons are a good idea.
MAF (all years) and TB (99^) stock MAF is adequate before this
97camastang03 is offline
Old 07-04-2010, 01:41 AM
Future4.3LStang
I already have a full plan for the car..
-Tom Morana 4.4L Stroker Rotating Assemble (Diamond Pistons, Scat Rods, All Bearings)
-New Ford 3.8L Cast Iron Block
-Tom Morana Stage 3 CNC’d Big Valve Race Heads (Flow over 300 Intake, 200 Exhaust)
-Tom Morana Custom Camshaft (Turbo/Nitrous Grind)
-Super Six Motorsports Rocker Arms
-ARP Head Stud Kit
-ARP Main Stud’s
-ARP Rod Bolts
-3 Layer Head Gaskets (Left and Right Side)
-Fluidyne Radiator
-Flex-a-lite 12” Fans
-Meizer Water Pump
-Melling Oil Pump
-Canton Oil Pan
-Miscellaneous Engine Stuff (Hoses, Belts, Clamps)
Rear End and Transmission
-BC Automotive Built 4R70W Automatic Transmission
-Circle D Specialties Pro III Torque Converter 3,400 Stall
-J Mod
-Mustang GT/Mach I 8.8” Rear End
-Moser 31 Spline Axles
-Detroit Tru Trac Differential
-Ford Racing Performance Products 3.73 Gears
Intake/Forced Induction/Nitrous
-Super Six Motorsports Sheetmetal Upper Intake Manifold
-Super Six Motorsports Ported Lower Intake
-BBK Ported 65MM Throttle Body
-Custom Turbo Kit made by Andy Littelton TMA Turbo(Hopefully!)(If not a D1R)
-Comp Turbo CT43-8079 Turbocharger
-Spearco 2-256 Intercooler (Rated to 1300hp)
-Tial Sport F41 Wastegate
-Tial Sport 50MM Blow Off Valve
-Aeromotive Oil Lines
-Tial Sport Miscellaneous Clamps
-Tial Sport Miscellaneous Hoses, Fittings, Adapters
-Miscellaneous 304 SS Piping
-ZEX Direct Port Nitrous Kit W/15lb Bottle
-ZEX Bottle Heater
-ZEX -6 Dual Purge Kit
-ZEX Bottle Opener
-ZEX Progressive Nitrous Controller
-AEM Methanol Injection Kit
Fuel System
-03/04 Cobra Fuel Tank
-Fore Precision Fuel Hat
- (2) Fort GT Supercar Pumps
-Tom Morana Fuel Rails
-Ford Racing 80lb Injectors
-Aeromotive Lines
-Aeromotive Filter
Electrical/Ignition/Computer
-MSD Ignition Module
-MSD 8.5MM Spark Plug Wires
-Optima Yellow Top Battery
-250 Amp Alternator
-SCT X3 Handheld Tuner
-Custom Tune from Car FX (1 Street 91 Oct Low Boost(10psi) Tune,1 Street 93 oct high boost(15) with meth tune,1 Full Race Tune C 16 Race Fuel 30psi)
Suspension
-Maximum Motorsports Street/Strip Package
-Maximum Motorsports Launch Package
-Maximum Motorsports 4 Point Cage W/ Removable Harness Bar
-Bear 13” Front Brake Kit
-Bear 14” Rear Brake Kit
-SLP Line Lock
Interior
- (2) Corbeau CR1 Racing Seats (Black Edge with Blue Inner Area)
-Corbeau Driver and Passenger Side Seat Brackets
-Corbeau 4 Point Racing Harnesses (Black)
-Corbeau Extra Material (Blue and Black)
-(2) Corbeau Logo’s
-Autometer Cobalt Wideband Air Fuel Gauge
-Autometer Cobalt Boost/Vacuum Gauge (30 Vacuum 40 Boost)
-Autometer Cobalt Oil Pressure Gauge
-Autometer Cobalt Nitrous Pressure Gauge
-Black Cat Gauges (Made to look like Autometer Cobalt Gauges)
-Gaugeplates.com Custom Gauge Panel (Nitrous Pressure Gauge, Boost Controller, Turbo Timer, Nitrous Arm Switch, Purge, Bottle Heater, and Bottle Opener)
-Hurst T-Shifter With Line Lock Button
-Main Part of Interior Re-Painted House of Kolor Jet Set Black (Professionally)
-Trim Pieces Painted House of Kolor Kandy Kobalt Blue (Professionally)
-All Stack Racing Billet Stuff that is available for Interior (All Powdercoated Kandy Cobalt Blue)
-Powdercoat Roll Cage Black
I.C.E (In Car Electronics)
-Jansen VM9312HD 7” Flip Out Touchscreen Head Unit
-Kenwood Front Speakers
-Kenwood Rear Speakers
-Kenwood 600W 4 Channel Amplifier
-Kenwood 1000W 2 Channel Amplifier
-Kenwood 12” Subwoofer
-Custom Box
Exterior
-Saleen Body Kit
-Mach II Hood
-AeroTach Flush Mount Hood Pins
-Custom “232T” Badges (Means 232 Turbo)(Just so they think its still a 3.8L)
-Stack Racing 8” Black Antenna
-Stack Racing Black Fuel Door
-Stack Racing Black License Frame Plate
-Black Lower Billet Grill
-Mach I Grill Delete
-Black Running Pony
-Custom Rocker Stripes “Honeycutt” (Black)
-Black Saleen Wheels
-Front 18x9 Wrapped in Nitto 275/35R/18 555R’s
-Rear 18x10 Wrapped in Nitto 305/35R/18 555R’s
-Weld ProStar Wheels (Powdercoated Black)
-Front 15x4.5 Wrapped in Mickey Thompson 4.5/22.5/15 ET Drags
-Rear 15x12 Wrapped in Mickey Thompson 26/22.5/15
Installation will be done by me/friends
Old 07-04-2010, 12:02 PM
jthorn9
The Godfather
jthorn9's Avatar
All I can say is I hope you have on hell of a job, because with all due respect, it's going to take a fortune to buy all of that, even over an extended period of time, and all in all, not worth it, invest your money in something better like bonds, a down payment on a new car, a down payment on a house, something more than a car.
jthorn9 is offline
Old 07-04-2010, 12:08 PM
flash20
flash20's Avatar
x2 thats alot money
flash20 is offline
Old 07-04-2010, 12:19 PM
torchred02
torchred02's Avatar
i had a list too..i realized i would never get everything i wanted
that is alot of money...
torchred02 is offline
Quick Reply: First Mods Plan
