Cheap Upgrades!
Look at the cost per hp rate. Here's an example
$160 per 4 hp = $40 per 1 hp on a cold air intake.
$2500 for all the parts needed for an M-112 Supercharger = 90 hp @ 8 psi = $27.7 per hp, hmm....doesn't sound expensive to me, on the contrary, cold air intakes are a rip on price wise.
I agree with gears and T-Lok. That was my first real mod. If you have the tools and someone who knows how to work on the rear end, it won't cost much. (However, you might want to hit your head against the wall trying to figure out how to remove the open differential...) Otherwise, $700 is about the minimum you could do it for, and that's with cheap parts and cheap labor.
Honestly, I'd just say wait. Save up every last dime you can Then you will eventually be able to get the M-112. Or a Gt. That's the only way to get massive gains.
well its not like i can't do the work myself i know what im doing but i don't what i should do... do when you say t-lock thats the rear diff right? like you mean posi? and so i take it gears and (t-lock) then supercharger and pullies?
