Dome light staying on...
So this is my first problem for the record
I guess it could be alot worse, But after work i got in my car and the dome light wouldn't go off. I slammed evrey door shut and its still on. I was looking for the typical spring thing but to my luck the mustangs dont have them. So i think just started poking random screws near the rear windows and the light went off somehow...
Which brings me to this question? Where is the door jamb switch? Was i close? And if this happens again can i just remove the dome light bulb to save my battery? Or will it still drain?
my friend thought he had a problem with his and it turns out he just didnt know the head light switch was what controlled the dome light lol.
not trying to insult your intellegence, just making sure you know this.
yeah i tried the dimmer / headlight ****, but it didn't really do anything. I twisted and pulled it every direction. Im convinced i have a defective door switch; or its stuck somehow. Where is the mechanism?
Id like to know, but maybe there is some kind of mechanism inside the door? either that or its near the rear window.
have the same problem i tried everything my dont go off either
Sorry, Ericko is right. It is where the car door is bolted to the frame. There will be a triangle "striker" plate on the frame between the door hinges, just opposite of that on the door you will find a little button you can push it. That is what your looking for.
Matthew
Matthew
