Cold-air?
Whelp looking through all of the options I leaned more to the MAC 73mm Straight kit.
It comes with a 73mm MAF housing, the tubing, filter, couplers and hardware.
Its a little expensive but mixed with a larger throttle body this is probably your best bet at an overall gain.
If I remember correctly the stock MAF size is 70mm.
Here is a link to an ebay listing to give you more info about it, you can probably find it cheaper than that too.
http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories
http://www.americanmuscle.com/muv6coairins.html
About to order that one for myself, cheap and seems to be a good product considering the price.
btw what he means by "Intake Spacer" is a phenolic spacer that fits between the upper and lower intake to slightly increase the runner length, increase runner cc and prevent heat soak into the upper intake manifold.
In case you thought throttle body spacer, dont get one. They are a waste of money.
The kit from American Muscle will do the same job as the much more expensive 73mm kit just without the 73mm TB.
You can add a 73mm MAF housing to this kit later down the road as well.
I just like the straight shot design and shield, it cuts out a power robbing bend and makes servicing the filter a lot easier.
If you want to stretch your cash though, the AM kit is the best bet.
