Fuel pump set up?
Old Sep 1, 2010 | 08:20 PM
Sideshow Bob's Avatar
Sideshow Bob
Default Fuel pump set up?
What would be the best fuel pump set up for the V6 trying to get 500+hp? Dual pumps or single. Im looking at two 255 pumps from Lightning force. or is there a single that would work better? Like the GT40 pump. I will be getting a larger fuel rail also.
Old Sep 3, 2010 | 05:49 AM
Sideshow Bob
Ok let me try it this way. What would be your DRAEM set up for your V6?
Old Sep 4, 2010 | 07:47 AM
Sideshow Bob
My bad I did a search and now I know everything about fuel pumps, fuel rails, fuel reg's, and so on. Now I'm looking for the 03-04 cobra pumps.
Old Sep 4, 2010 | 01:41 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
That or a SVT Focus pump. Alot of people use those too
Matthew
Old Sep 4, 2010 | 11:09 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Sump'd tank, returnless, a1000...
Old Sep 4, 2010 | 11:18 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I would just run a cobra hat and tank, with supercar pumps, I believe the FPDM has to be upgraded, but I'm not 100%, you could also just run a boost-a-pump
I have to agree with the above for the dream setup, also through some big fat -AN lines
Old Sep 5, 2010 | 07:05 AM
Sideshow Bob
I found a 01 GT pump with tank on the G-list for 40.00 bucks. But I think I'll keep looking.
Old Sep 5, 2010 | 07:50 AM
Sideshow Bob
$1,295.00 Well I guss I had that coming, ok your dream set up for under $300.00 bucks.
Old Sep 5, 2010 | 12:31 PM
RyansQuick6
Reverse Gear Member
The GT tank and pump is the same as the stock v6 stuff. i bought my Termi tank for $450 shipped off of SVTP. The Termi tank, and ONLY the termi tank, has a baffle built in it. The Mach/GT/V6 tank and pump setups are all the same.
Old Sep 5, 2010 | 02:57 PM
Sideshow Bob
Thanks RyansQuicks6
Is the pump out of the 03-04 cobra going to be my best bet? If so will it drop right in the tank I have now (stock) Or will I have to mod?
I found one at a junk yard but they want $250.00 just for the pump. deal or no deal? I'm thinking that the cobra pump is good for 800hp or so.
