P/P lower intake
Old Oct 4, 2010 | 11:50 PM
xToPPxDoGGx's Avatar
xToPPxDoGGx
Default P/P lower intake
im not looking to go all out with my motor build and putting the car down for a while but i just wanna add alittle hp without doing anything too drastic i was thinking about doing a P/P lower intake from super six, i have already have a windstar intake i thought maybe the lower intake would be a pretty good add on to it , i know i wont get as much HP from it if i would build the motor but would this be good to do? and would just doing the lower intake have any bad side effects or cause any damage ?? also other parts i was wondering the same thing about was next size up fuel injecters? MAF? any other suggestions on upgrades ??.... or maybe should i just suck it up and do the cam and heads as well?
Old Oct 5, 2010 | 04:28 AM
Fink's Avatar
Fink
Might as well do the cam while you have the lower off. No need to worry about the heads, gasket match to the lower at least.
You will see a nice power gain from cam/ported lower and windstar. Arent you also putting LT's on?
Old Oct 5, 2010 | 10:00 AM
xToPPxDoGGx
yea im doing long tubes also, so i should skip heads ? even if there the stage two heads? i thought i read some where to benefit from the cam it would be best to do heads but i could be really wrong
Old Oct 5, 2010 | 10:36 AM
Shaunmac9128's Avatar
Shaunmac9128
The cam will gain more with the heads obviously but the heads are very expensive and the windstar and ported lower are not that expensive. You can get 240rwhp out of windstar ported lower cam longtubes and a tune.
Old Oct 5, 2010 | 03:23 PM
xToPPxDoGGx
Really!?, do u think it would cause any stress or damage to the engine without the heads being done?
Old Oct 5, 2010 | 04:53 PM
Fink's Avatar
Fink
No. The cam is more of a bottleneck on our cars than the heads. Like I said, at least gasket match the heads to the lower intake.
Old Oct 5, 2010 | 10:20 PM
Shaunmac9128
With gasket matched heads and the right cam/tune I see no problem reaching 250 to the wheels based on other setups.
Old Oct 6, 2010 | 01:09 PM
Polkaudio's Avatar
Polkaudio
Go for it! I recently added the Windstar upper and SSMS ported lower at the same time and I love it!
Old Oct 6, 2010 | 01:21 PM
xToPPxDoGGx
How much did ur lower intake run you?
Old Oct 6, 2010 | 01:31 PM
Polkaudio's Avatar
Polkaudio
It was $450 from SSMS, but that combination is probably the best we can do on our cars N/A. I'm in the process of trying to figure out my next move (cam or LTs).
