speedo issue
so my speedo and odometer don't work
i replaced the speed sensor and tranny gear which was all chewed up and still nothing
i also took my cluster out and looked at all the small gears back there and they all seemed to be good so im at a dead end with ideas here
i could always get a new cluster and hope that was the problem but i don't want to spend the money not knowing its that
not sure if my 94 has a cable, idk my mechanic replaced the sensor n gear and told me i have power going to the cluster now and i told him i would take it from there
i looked at the gears in the gauge cluster and they looked ok but i'll take them out and carefully inspect them, i only didnt b/c i thought they had to do with just the odometer and both my speedometer n odo dont work
Vehicle Speed Sensor. It's what your speedo gear sits on. I changed my gear, checked my cluster, checked all fuses, and replaced the sensor itself, no go. So I've got to check the wires leading to the sensor's harness, I may have messed them up when I tried to instell my Dallas SpeedCal.
