Couple questions, 2003 v6
Old Nov 1, 2010 | 03:12 PM
rjoslin24's Avatar
rjoslin24
Default Couple questions, 2003 v6
When i start my car, and when Im driving, I hear a clicking from the front, my friend said my alternator is going bad, is this probably the case? Also, It makes a kind of whining sound when idle and driving, and sometimes turning. I was wondering if all mustangs do that, or is it something I can fix? Thanks, new here, looks pretty cool here.
Old Nov 1, 2010 | 03:17 PM
03shadow's Avatar
03shadow
the whining noise sounds like its the power steering pump. no worries, im pretty sure that everyone here will say theirs does it. the clicking could be something unrelated though. and welcome to MF! it is cool here
Old Nov 1, 2010 | 03:19 PM
rjoslin24's Avatar
rjoslin24
is the power steering pump in need of replacing then? and thanks for the welcome
Old Nov 1, 2010 | 03:23 PM
rjoslin24's Avatar
rjoslin24
oh and by the way, i just looked at the pictures of your mustang, its really nice! where did you get the mach 1 cluster from? and did you program it to have the same mileage as your car? or is it different? kind of off topic, but wanted to ask.
Old Nov 1, 2010 | 03:34 PM
03shadow's Avatar
03shadow
it should be alright. if you notice that the steering wheel is hard to turn sometimes and other times its normal, then the power steering pump would need replaced. just make sure you have enough fluid in there.
thanks, i got it off ebay, it was from a totaled car in a yard from canada. i didnt have it reprogrammed, my car should have about 63k on it
Old Nov 1, 2010 | 08:12 PM
98ponycar's Avatar
98ponycar
Are you running your A/C when you hear the clicking? Compressor clutch could be rapidly engaging and disengaging caused from a low refrigerant level. As far as the whine, I would check all the pulley bearings and make sure they sound good, and check the p/s fluid. If all is fine, then it is probably the already mentioned notorious power steering whine, which is nothing to worry about.
Old Nov 4, 2010 | 02:11 PM
rjoslin24's Avatar
rjoslin24
no im not running the a/c when it happens, but when I do run the a/c it sounds like the fan blowing the a/c is clicking too now to mention it. but I dont use it much. It sounds like the alternator, I started it up and popped the hood, and the sound was coming from inside or right next to the alternator
Old Nov 4, 2010 | 04:25 PM
03shadow's Avatar
03shadow
compressor runs while running heat too, not just A/C
Old Nov 4, 2010 | 04:56 PM
Daehawk's Avatar
Daehawk
I say power steering too on the hum. Fill it up.
the clicking could be a few thing...valve, timing, or mostly on these the exhaust manifold. mine clicks a little too. I have headers though so know it aint that lol. I dont worry with mine,...yet.
Old Nov 4, 2010 | 08:14 PM
98ponycar's Avatar
98ponycar
No the compressor does not run when running the heater. It runs when running the defrost, but not the heater.
