need help
Old Nov 21, 2010 | 07:13 PM
grim_reaper's Avatar
grim_reaper
Default need help
i got a 2000 mustang gt rolling chassis. Then I picked up a 95 v6 swap. What mounts do I have to use to make this work and the car has a qa1 k-member in it and the car was a v8 before. Also if i used motor plates should i use a blank 1 for the front and make it or is there 1 I can use. The last question what makes the 95 blocks so weak?
Old Nov 22, 2010 | 05:54 AM
LilRoush's Avatar
LilRoush
'95 block isn't weak. They have been proven to take 900 hp.
You'll need the '95 motor mounts.
Old Nov 22, 2010 | 05:45 PM
grim_reaper
thanks man also do u know what drive shaft I can use with a 8.8 rear and aod trans
Old Nov 23, 2010 | 07:34 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
WHy would you swap in a 95? did you do a split port swap?
Old Nov 23, 2010 | 08:05 PM
grim_reaper
i just pick up the rolling chassis from a friend and found the 95 swap for cheap
Old Nov 24, 2010 | 07:25 AM
RyansQuick6
Reverse Gear Member
I'm about 95% sure that doing that swap is illegal in VA, as in most states. You typically can't swap and older model engine into a newer model car.
Old Nov 24, 2010 | 07:25 PM
LilRoush's Avatar
LilRoush
True... didn't even cross my mind.
Look for a wrecked F150 to buy a 4.2L V6 out of and drop that in. More power, same money.
