Radiator issue
Old Jan 7, 2011 | 12:48 PM
Eileen's Avatar
Eileen
Default Radiator issue
Can a 99 radiator leak be repaired or must the whole radiator be replaced? Please help. Fuel pump, radiator, alternator and battery went as same time.
Old Jan 7, 2011 | 02:32 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
If the plastic end caps are where the leak is, then I'd recommend replacement, if it's in the center, then a radiator shop should be able to repair it. Also replace your thermostat and flush the cooling when you put the repaired/replaced radiator in
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
