AC/Heater vent problem
Old Jan 12, 2011 | 12:04 PM
the04hurricane's Avatar
the04hurricane
Default AC/Heater vent problem
I have a problem with my center console vents... they do not blow air at all. The other vents work no problem, so its not the blower core. Any suggestions?
Old Jan 12, 2011 | 03:21 PM
Daehawk's Avatar
Daehawk
Ok you can laugh at me....I thought my center ones didn't work or work well. I mean all dang summer when I got the car. Turns out some smarty had taken them out and put them back reversed or upside down. So the vent control for airflow when it was in the same position as the other vents was actualy closed instead of open. The little roller wheel beside the vents themselves. So mine has to be up to be open instead of down to be open lol.
If it's not that then I'd check real close to see if that is working. then I'd check the venting behind the dash to see how it is. Most likely though it has something to do with the little plastic door in the vents.
Old Jan 12, 2011 | 03:41 PM
NeoTokyo's Avatar
NeoTokyo
There is plastic tubing that is loosely snapped together, this can come loose and just needs to be re-snapped into place.
There is only 1 blower fan for the whole system so being that your other vents work that tells me that it just came loose, that or there is a rats nest in there.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Beerman309
Sep 19, 2015 01:16 AM
tmdm
Sep 4, 2015 06:45 PM
