lt headers
Old Jan 25, 2011 | 10:35 AM
d.girardi's Avatar
d.girardi
Default lt headers
So I decided I'm finally gonna get some LT headers. I'm going with the pacesetter black LT's without the EGR. Will I need a tuner or anything else besides the headers?
Old Jan 25, 2011 | 12:40 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Since you're using pacesetter and not MAC, you're gonna need a lot of stuff. Tuner, custom h-pipe, catback, cats, egr delete, and an inspection station that will pass you.
Old Jan 25, 2011 | 12:47 PM
RyansQuick6
Reverse Gear Member
You can order MAC's, ceramic coated, a MAC h-pipe, and catback, and retain your O2's and EGR, no tuner needed. You just have to get 2 cats welded into the h-pipe.
Running no cats will sound terrible.
Old Jan 25, 2011 | 02:43 PM
NeoTokyo's Avatar
NeoTokyo
As much as I like Pacesetter as a company for their customer service and other products, their headers are not the best option in this case.
If you got some sort of a crazy deal you could always weld an EGR bung in (rear pass side primary if I remember right) and make your own midpipe, otherwise I would stick with MAC.
Old Jan 25, 2011 | 05:16 PM
Daehawk's Avatar
Daehawk
I vote MAC too..but then I would
Old Jan 26, 2011 | 08:12 AM
d.girardi's Avatar
d.girardi
I was honestly just going with pacesetter cuz I found a pair for like 150. Guess ill go with Mac.
Old Jan 26, 2011 | 05:32 PM
mustangman02232's Avatar
mustangman02232
MAC and highflows or bust
Old Feb 7, 2011 | 10:48 AM
d.girardi's Avatar
d.girardi
So I will not need anything aside from lt's, h pipe, mufflers, tips then piping?
Old Feb 7, 2011 | 11:19 AM
mustang99v6's Avatar
mustang99v6
Hey ryan, I was told that you have to get a tune because the 02's are moved downstream and the car won't run right....?
Old Feb 7, 2011 | 11:36 AM
NeoTokyo's Avatar
NeoTokyo
You can either turn off the rear two (Tune.)
Or you can put a couple high flows in and weld an O2 bung after the cats so you have one before and after the cats. (No Tune.)
d.girardi Pacesetter makes a LT with EGR fittings to fit your 04', why not go for that and get the custom midpipe made? You will have to find a shop that is willing to do it to factory spec so you can use GT takeoffs. A lot of shops will want to set it up their own way keeping you from being able to easily swap catbacks out.
Based on price and headache the MAC's are still a better choice.
