HELP ME!
Old Jan 28, 2011 | 01:50 AM
David Choy's Avatar
David Choy
Default HELP ME!
I have an automatic 3.8L mustang but im planning on converting it to a 5.0 but first i wanna change the trany to a 5 speed. Can anyone give me a list of what i need to get please i know i need the t45 trany, clutch pedal, clutch cable, flywheel, and thats all i know and if possible someone throw me a estimate..
Thank you
Old Jan 28, 2011 | 02:15 AM
NeoTokyo's Avatar
NeoTokyo
The T45 transmission will not fit a 3.8L or a 5.0L, it will only fit a mod motor (4.6L, 5.4L).
You need a T5 for your conversion and it needs to stay within your year range, 94-98 and 99-04. The reason behind that is 94-98 used a mechanical speedo pickup and 99-04 used an electronic pickup.
If you are thinking of swapping the trans in hopes of completing part of your swap then you need to look at a GT spec, trans. The FRPP HD T5 is a great trans but the input shaft will be a hair short (5/16" I think)
You have several options for a transmission.
Now there are adapter kits out there to use a T56 on a 5.0L from D&D Performance in case thats something that you want to do.
http://www.ddperformance.com/
Old Jan 28, 2011 | 08:42 AM
brent4's Avatar
brent4
^ I thought there was also an adapter for the t45 and t3550 to fit the 3.8/5.0 also?
Old Jan 28, 2011 | 06:41 PM
v6stang07's Avatar
v6stang07
you should really switch the tranny and motor at the same time. honestly that is a lot of money it would be more beneficial to start with a new car that you actually want to work with
