solid motor mounts
Old Feb 4, 2011 | 11:45 PM
stangant's Avatar
stangant
Default solid motor mounts
Will these work or does anyone know of some that will?
http://www.americanmuscle.com/mm-sol...unts-9604.html
Old Feb 5, 2011 | 05:36 AM
NeoTokyo's Avatar
NeoTokyo
If not they can be easily modified to work at least.
Old Feb 5, 2011 | 05:45 AM
stangant's Avatar
stangant
yea the k-members i know are the same. At least the MM tube k-members are so I figure it would be the same, just strange everyone leaves out our model.
Old Feb 5, 2011 | 10:30 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I wouldn't run solids on a street care, it's horrible
Old Feb 6, 2011 | 03:17 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Nobody makes solid motor mounts for this car...
If you try to mod the GT mounts, let me know how that works out for you.
Why would you need them is the real question?
Old Feb 6, 2011 | 08:55 AM
mustangman02232's Avatar
mustangman02232
you could just make a set if your any type of a fabricator. you need to put a solid tranny mounts to.
Old Feb 6, 2011 | 11:53 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
No, don't do that!
Solid motor mounts and a poly trans mount, something that can flex.
Old Feb 6, 2011 | 12:06 PM
mustangman02232
Originally Posted by ESG-642T
No, don't do that!
if the trans can flex while the motor is solid doesnt that run a risk of cracking the tranny open? we put a set in a my old toyota like 5 years ago and i thought we did both for that reason, i could be mistaken thought there has been a lot of beer in my life that could be clouding my mind
Old Feb 6, 2011 | 01:08 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Nope if the trans CAN'T flex you'll crack the case....
When you get into race cars where the chasis is stiff enough it doesn't really matter.
Old Feb 6, 2011 | 03:39 PM
RyansQuick6
Reverse Gear Member
I've actually seen people have issues with solid motor mounts and poly trans mount, you actually need to use rubber on the tranny when running solids. Poly's all the way around is ok though.
