Aligment is not getting perfect help!
Old Feb 24, 2011 | 08:38 AM
reddeth90's Avatar
reddeth90
Default Aligment is not getting perfect help!
So I've been on a wild goose chase to get my stang aligned. I has stock suspension and nothing ha been done to it. I already replaced the end tie rods bit the wheel still goes to the right and the car goes straight. I haven't checked the air pressure yet to even everything out, if tire pressure can effect the mustang's wheel very easily. I need help. I'm lucky that I'm in the auto class in college because they do it for free but I'm tired of bringing it in.
Old Feb 24, 2011 | 12:46 PM
MustangSally94's Avatar
MustangSally94
if the tire pressure is not the cause, which ive never heard of but I guess could be possible? and your front end is in good shape I would suggest a caster/camber kit. It will give you a wider alignment option to get it right.... are you aligning it digitally or something else? If you can get it on a digital alignment machine you could get it perfect with the caster/camber kit
Old Feb 24, 2011 | 01:05 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Maybe you just need to have someone that's better at it to align it, unl;ess you've bent the hell out of a control arm or something.
Old Feb 24, 2011 | 02:31 PM
NeoTokyo's Avatar
NeoTokyo
+1
Have them walk you through it too if you can so you can learn from what your are doing wrong.
FivePointToTheOh
Mar 9, 2020 10:26 PM
ctgreddy
Oct 14, 2015 09:05 PM
Oct 1, 2015 09:29 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
