First off, what is the difference between Cross drilled brake rotors and normal brake rotors?
Second, what brand of rotors and pads should I buy for my 97 5 speed?
The cross drilled offer better braking power and also distribute heat better. The normal brake rotors are flat and across. I have PowerSlot rotors (slotted rotors, not cross drilled) and ceramic brake pads (forgot which brand but they were Hawks.) They both have performed very well for me.
If the car is stock and no real upgrades then OEM rotors and pads are pads are fine. What do you use the car for? Is it a DD, are you trying to upgrade to make it a track car?
Its a daily driver, have a long commute through downtown Indianapolis and drive it hard. I just want to know if I am having fun I can get stopped quickly
