Procharger question
Old Feb 26, 2011 | 07:52 PM
THE04mustang's Avatar
THE04mustang
Default Procharger question
I have an 04 3.9l mustang completely stock and I want to buy and install a pro charger but I'm not sure if I need anything else or need to be worried about anything breaking? Like the rear end or tranny breaking?
Old Feb 26, 2011 | 10:48 PM
neo8222's Avatar
neo8222
yeah you can't really bolt on that much extra power without upgrading the other stuff behind the engine and expect it to last, if you do that you'll have made a grenade.
Old Feb 27, 2011 | 12:00 AM
Itz_Gizzy's Avatar
Itz_Gizzy
You understand that a procharger is no small task, nor cheap, right?? If you want to simply make your car faster, you should look for smaller, WAY less expensive bolt-ons. You can upgrade the headers, get cams, change around the exhaust, get gears, a tune, cold air intakes, etc etc.
There are plenty of things you can do to make your car faster, that are way less expensive than installing an entire procharger system. However, if you're dead set on installing a procharger, you'll need many upgraded parts. Look around on Procharger's website, as well as these forums for a detailed list.
Hope this helps! And good luck with your modding, sir.
Old Feb 27, 2011 | 04:01 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
procharger
fuel injectors
fuel pump
detroit true trac or 8.8 (rear end)
upgraded clutch (if auto don't touch it, maybe add a j-mod or trans cooler)
get it tuned
enjoy.
**however I would suggest going turbo**
Old Feb 27, 2011 | 02:56 PM
JKs95stang's Avatar
JKs95stang
There is only one cam in a push rod engine FYI. It's not a modular that requires two. Go with some gears first, drop in K& N and some pulleys, dual's with H pipe, that should free up a few pony's.
Old Feb 27, 2011 | 07:07 PM
jthorn9's Avatar
jthorn9
The Godfather
A supercharger is the best thing to do, a cam, heads, ported intake, etc will put more strain on the fuel system for the HP yield and will make your car get much worse MPG, which is getting to be a bad thing with gas steeply climbing again.
As long as you don't run more than 10 PSI max, your engine will be fine. Your stock fuel injectors will not support the load nor will your fuel pump. The transmission will hold up to around 300-350 torque, so you'll be on the fringe there but you should still be fine. The rear end needs to be swapped however, and with an S/C I wouldn't run any higher than 3.73 cause all you'll do is burn rubber off the line and have no control.
Old Feb 27, 2011 | 07:59 PM
SON1C's Avatar
SON1C
esg could you do a s/c vs turbo comparison?
Old Feb 27, 2011 | 10:04 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
I've done enough of them, but i'll send you a PM....
and JK, when you start lighting tires up off the line, you switch to a better tire
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
