What would you suggest?
Old May 25, 2011 | 04:13 PM
The grey beast's Avatar
The grey beast
Default What would you suggest?
All opinions are welcome on this:
I am planning some mods, and have taken into consideration turbos. Now would it be better to do a turbo system? or simply do an engine swap? or procharger? plz comment
Old May 25, 2011 | 08:35 PM
03shadow's Avatar
03shadow
well it depends on your power goals and what you want to do with the car? are you just looking for it to have more power or are you looking to do any organized racing?
Old May 26, 2011 | 07:42 PM
The grey beast
Well at the present time im just looking for some more power in general
Old May 27, 2011 | 01:22 PM
03shadow's Avatar
03shadow
hmmm i think a procharger kit designed for our cars would be the easiest of an install and get ahold of
Old May 27, 2011 | 03:25 PM
The grey beast
How much hp does a procharger add?
Old May 28, 2011 | 07:54 AM
NeoTokyo's Avatar
NeoTokyo
They say 45-75% increase but its all relative to your mods and boost and tune.
You can push the limits of your engine with a P1SC before you push the limits of the blower.
Its a very good system to build around.
If you dont want to spend that much and want awesome off idle power, check out a M112 conversion.
Turbo's are a great (A lot argue the best) system too.
Old May 28, 2011 | 07:59 AM
NeoTokyo's Avatar
NeoTokyo
btw, power wise, those that run the kit say around 260-270hp to the tires in stock trim.
I found a thread where ATI said the kit makes 34RWHP more than a stock 2001 GT. Both cars were Auto's.
Old May 28, 2011 | 11:17 AM
The grey beast
Alright thanks neo, lot to think about, because im not sure if im gettin either one of these, but if i do ill have to plan out a whole new build....which will happen eventually anyways, might as well do it the best way the first time
Old May 28, 2011 | 11:53 AM
NeoTokyo's Avatar
NeoTokyo
No Problem.
The stock engine can take quite a bit, 325-350rwhp are save levels for Supercharged setups. You might be happy with that performance and decide to work over your suspension and reduce drivetrain loss or vehicle weight.
300rwhp in a well ballanced machine is a lot of fun.
Old May 28, 2011 | 12:32 PM
The grey beast
Haha i would say so, man i want to get some money so i can get started on some mods
