Power Port
Old Jun 1, 2011 | 10:18 AM
billytk's Avatar
billytk
Default Power Port
So I just noticed my power port in the center console isn't working, does anyone have any suggestions on what this could be? Also if someone can point me towards a "how to" on opening up the console to be able to check the connections behind the port that would be GREATLY appreciated.
Old Jun 1, 2011 | 04:41 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Here is a write up I did a while ago. Yes my spelling is HORRIBLE but you get the point.
https://mustangforums.com/forum/v6-1...icky-post.html
Let me know if you have any questions.
Matthew
Old Jun 2, 2011 | 09:31 AM
billytk's Avatar
billytk
THANKS Matt, that's a great write up. Quick question before I open everything up, I have a V6 and I believe the fog lights were added aftermarket, I pulled out the power port and it wasn't connected to anything (so that's obviously why there was no power lol) but looking through the opening I couldn't see any wires that it would plug into so my question is this (sorry if this is stupid) when they wired the fog light switch in is there any reason they may have removed the receptacle for the power port?
Old Jun 2, 2011 | 03:44 PM
Matt's 95 Stang
Resident Ginger
If I remember correctly 94 and 95 were the only years they put the convertable and foglight wiring in place no matter if it was a coupe, or a V6. After that they (Ford) didnt run the wires because it cost money and there was no need to have foglight wiring on a V6 (as it didnt have foglights). I would have to see a pic of the underside of your console to know exactly what you are talking about. If you do have aftermarket foglights that work on the OEM foglight switch it is possible whoever installed the kit might have taken the power from the "power receptacle" and used it for the foglights. Or they simply pulled of the wire by accident.
Matthew
Old Jun 3, 2011 | 08:59 AM
compdude97's Avatar
compdude97
My 97 has the foglight and vert wiring, so they were still doing it then.
Old Jun 3, 2011 | 03:15 PM
Matt's 95 Stang
Resident Ginger
Well there you go. I learn something new everyday. Maybe they did it till 98.
Matthew
Old Jun 21, 2011 | 04:51 AM
petrock's Avatar
petrock
Did you check the fuse box? My girlies power plug/cigarette lighter didn't work and it turned out to be a blown fuse.
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
