Bad PCM??
Hi, my mustang 1994 V6 with manual transmission has weired problem. It comes and goes, sometimes when driving over a bumpy road it will happen.
Mostly it runs well. BUT sometimes stalling suddenly happens and my mustang has very few power. Even it cannot go up the hill. If I floor the gas the car wont go but if I ease on the gas the car starts to build revs. The engine check light comes on but then it goes away. It has a Predator chip in the ECU from the previous owner and my OBDII says the check engine light is from a too rich fuel mixture. I think the chip might be messing up the fuel mapping. Can I just remove the chip?? My car also has an aftermarket exhaust so could the O2 sensor be malfunctioning? All of this work was done by the previous owner and I bought the car from a dealer so I have no way of getting in contact with the previous owner.
I already changed the coil pack, spark plug wire, and crank angle sensor.
When I turn the ignition the fuel pump keeps making noise before I start the car and the radiator fan also turns on even when the car is cold.
Sounds like too rich gas to spark when this hesitation happens. Black smoke comes out from muffler and i checked the plugs. The plugs were wet with gas.
l cleaned injectors by putting chemical in vacuum hose. But it did not make any difference
KingRando
Oct 2, 2015 08:06 AM
