HELP!!!
Old Dec 23, 2011 | 09:08 AM
usarmy2010!!'s Avatar
usarmy2010!!
Unhappy HELP!!!
Ok so i have a 95' 3.8l v6 mustang, and someone cut two of the wires that go to my mass airflow sensor. now the car runs crappy. it has no power and sputters really bad at high rpms... i have no idea what to do to fix it. i have put the wires back togeather and they have a good connection... but still sputters really bad... my thought was something happened to the mass airflow sensor and thinking about buying a new one but before i do i was looking for ideas. thanks to whoever can help.
Old Dec 23, 2011 | 01:19 PM
green232's Avatar
green232
take the sensor out and clean it really well.. if that doesnt help, i would double check your connections, and be sure your computer doesnt still think it is bad.. try clearing any codes.
Old Dec 23, 2011 | 03:38 PM
usarmy2010!!
could i buy a new comp just to be on the safe side cuz i have cleaned the sensor with cleaner and i have double checked the wires.... does the problem sound like it is coming from the mafs
Old Dec 23, 2011 | 03:40 PM
usarmy2010!!
also how would i go about clearing the codes?
Old Dec 23, 2011 | 06:51 PM
belairbrian's Avatar
belairbrian
Disconnect the battery and let it sit for say 15 minutes or so, that will clear the codes.
A long shot, but cutting the wires may have caused a short long enough to blow a fuse.
Old Dec 23, 2011 | 07:04 PM
usarmy2010!!
ok ill try that stuff but still taking all thoughts on the subject so anyone else who reads this please post your opinion. thank you for the answers i have gotten so far
Old Dec 23, 2011 | 07:22 PM
DRAGUL's Avatar
DRAGUL
Did you solder the wires or just crimp them together. Also not sure but maybe it is ground specific, as it could be possible there is a positive side etc... Computer may not read it right if the wires are crossed?
Old Dec 23, 2011 | 07:52 PM
usarmy2010!!
the wires are right and i crimped it togeather would soldering the wires be better?
Old Dec 23, 2011 | 07:58 PM
DRAGUL's Avatar
DRAGUL
Yes it is a better connection than crimping. Also less susceptible to corrosion and shorts. I never use crimp on terminals. Solder and use heat shrink tubing.
Old Dec 23, 2011 | 08:01 PM
johngt10's Avatar
johngt10
Did someone cut these wires on purpose? If so could there be any other wires you missed?? Maybe check your plug wires
