Need Help
Old Feb 20, 2012 | 02:08 PM
mustang95and2's Avatar
mustang95and2
Exclamation Need Help
I have a 2002 V6 mustang nothing done to it exept a little chip tune from a sct hand held tunner. i recently replaced my air filter with a k&n and changed my oil with full synthetic oil. the first day i had the k&n filter on the car it ran perfect but the second day i ran it, it started to loose alot of power and now its misfiring when i go up hills, if i have it in nuetral and press on the gas its like its bogging down and hesitating. i read that i could have been the mass air flow sensor so i cleaned that and its still happening. if anyone has any ideas on what could be giving me these problems any help would be appriciated.
Old Feb 22, 2012 | 10:23 PM
ramair351's Avatar
ramair351
no check engine light or trouble codes? did you try putting your stock tune back in? maybe some sensor got unplugged while doing the filter. did you take the plastic wrap off the filter? ( i know, dumb question, but look at the obvious things first)
Old Feb 23, 2012 | 11:45 AM
jthorn9's Avatar
jthorn9
The Godfather
The K&N doesn't make a noticible difference to cause any porblems with your year car. Your problem likely lies with the ignition system or while installing everything you knocked a vacuum line loose which deffinitely will cause that kind of problem.
Old Feb 25, 2012 | 01:02 PM
ramair351's Avatar
ramair351
please keep us posted as to what you find wrong..
