Check Engine Light is FLASHING
Old Aug 27, 2012 | 07:45 PM
anderse's Avatar
anderse
Default Check Engine Light is FLASHING
To make a long story short: Does a 2003 Ford Mustang 3.8L with 83,000 miles. My Service Engine Soon light has been illuminated for many months now because of misfire in cylinder 3 The car has new sparkplugs, sparkplugwires, fuelinjectors cleaned and new fuel filter. The car has also gone a bit rough, but today everything went wrong.
Because of Isaac, I was looking to driving in heavy rainshowers, and the water splashed in all directions because the streets were flooded. After a few minutes driving the car began to run rough (all the car was shaking), loss of power and the Check Engine light started flashing!
On the way into the garage I was able to record a high-pitched sound awful from the engine, and the exhaust smells a bit like fireworks.
(Hear the engine sound here: http://www.2shared.com/audio/y6sEN_v5/mustang.html)
I got a code scanner, but it showed no new error messages Besides misfire in cylinder 3, but it has been there a long time now.
Any idea what this can be?
Old Aug 27, 2012 | 08:48 PM
dannyvee1981's Avatar
dannyvee1981
Are the spark plugs gapped correctly? I had that issue once, plus check the grounds.
Old Aug 27, 2012 | 09:11 PM
BabyGT's Avatar
BabyGT
Possible bad coil would be my guess.
Old Aug 27, 2012 | 09:12 PM
belairbrian's Avatar
belairbrian
squealing after water is likely a slipping belt, which can cause any number of problems.
Maybe someone else will listen to the file but, not interested in downloading a file from an unknown sight
Old Aug 28, 2012 | 04:44 AM
NeoTokyo's Avatar
NeoTokyo
This really sounds like a bad/cracked coil pack.
Go down to your local parts store and grab a new one, you can put it on yourself in just a couple of minutes.
My 01' had the same coil pack that your 03' has and mine had the same issue.
I bought the Borg Warner with a lifetime warranty and it did great, if you can not find that one then try to get another Motorcraft unit.
Old Aug 28, 2012 | 10:57 AM
anderse's Avatar
anderse
Thank you guys! I switched the ignitioncoil today, and everything is now working. The CEL have been illuminated since I bought the car, is now gone, and the car is running smoother than ever
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
