Performance MOD Planning
Old Sep 25, 2012 | 03:21 PM
gennss's Avatar
gennss
Default Performance MOD Planning
Well I have a 94. Which according to what I've read is at about 145hp, probably less at the wheel.
I'd like to get to 200 or 220ish without power adder. (I'll get to this later).
I'm thinking the least expensive way to do this would be a split port conversion and then the bolt-ons + tune. (CAI, UDP, Intake Spacer, etc).
Is this right?
Old Sep 25, 2012 | 04:02 PM
TomKat's Avatar
TomKat
also headers mid pipe and exhaust system maybe a cam
Old Sep 25, 2012 | 05:02 PM
1slomaro's Avatar
1slomaro
Split port swap, windstar intake, tune, and long tubes should get you around that. I'd add a cam while you're doing all that for a nice boost. You also need gears and a LSD to put that power to the ground
Old Sep 25, 2012 | 05:03 PM
jthorn9's Avatar
jthorn9
The Godfather
Is this right?
200-220 rwhp will not happen with bolt ons with either setup. Split port swap will put you at around 160 rwhp, full bolt on will only push you up to 170-180 rwhp depending on the dyno.
In short, FI will be by far the cheapest route. Power pack split ports (heads/cam/intake) cars only yield 200-220 depending on the cam. These kits will run around $2500 plus labor or about 1-2 days of work to do the swap.
A super charger on your single port will put you near where you want to be. With a split port swap would put you a little above that.
Main thing is to focus on mods that actually improve performance. Dyno numbers are often irrelevant as they will vary from dyno to dyno and aren't a given indicator of the cars performance. Example, the Shelby GT500 makes as much power as a 2012 Lambo, yet the lambo is around 1 second faster in the 1/4 mile and can run circles around the Shelby at the track. Granted I'm comparing a $250,000 car to a $60,000 car, but the point applies. Dyno numbers aren't everything.
So with all that said, think about what you want out of the car and go from there. If this is a car you don't see owning more than 5 years, then don't do much. You'll never get any money back out of the car. If it's something you're gonna own a long time then focus on things that will actually improve performance.
* Split port swap is on the right track, will yield 3/4 to 1 second better 1/4 mile times
* Larger brakes, will drastically improve stopping power and reliability
* Lower the car and add in lower car arms, strut tower brace, and lower sway bars, will moderately improve handling and response around corners
* 8.8" rear end with aftermarket gears, much stronger than stock, do at the same time as the brakes, and will give much better traction and control as well as improve 1/4 mile times by around 1/3 to 1/2 a second.
* Supercharger, this will be the best bang for the buck mod, will allow the car to maintain it's stock signature but with instant power when you need it. Will yield 1-2 second better 1/4 mile times (boost levels pending).
Old Sep 25, 2012 | 05:09 PM
1slomaro's Avatar
1slomaro
If he's talking crank hp, then 220 is easily possible
Old Sep 25, 2012 | 05:14 PM
Soldier GT's Avatar
Soldier GT
^^Yeah but it's gonna be exspensive as he**....
Old Sep 26, 2012 | 07:52 AM
gennss's Avatar
gennss
Just a little background. I'm in my 30s, this is our second car. I'd like to be more involved in the building process than I have with my previous vehicles. No payments, No Warranty, it's old as hell, It smells weird, and it's my pet project =).
I was measuring at the flywheel, so your numbers look about to what I was expecting.
I'd like to make the improvements gradual because this car is more about the mechanical experience as a hobbyist than it is about taking it to the track.
so I'm looking at about $3000 for Splitportswap/SSM Powerpack right?
then and/or about another 3-4k for the SC if I go with a procharger. M112 will require a split port swap and m90 won't put me to where I want to be or will top me off too quickly.
Actually doing some research I think an SC will bump to to my goals. I'm not looking for much more than 13s. Opinion?
Old Sep 26, 2012 | 08:20 AM
1slomaro's Avatar
1slomaro
I believe a supercharger with split port swap might get you to high 13s
Old Sep 26, 2012 | 11:15 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
The M90 with SSM heads and a FMIC will get you really nice power...just sayin
Matthew
Old Sep 26, 2012 | 01:10 PM
jthorn9's Avatar
jthorn9
The Godfather
Keep in mind the M90 requires a lot of secondary work. In short you are better getting a used supercoup motor and doing a motor swap and customizing the few minor things to make it fit than trying to find all the other parts needed.
Also keep in mind a split port swap isn't a direct swap either. It's easier than the M90, but will also require more than just the heads and intake.
A centifugal supercharger would work better for you and your application, not to mention will be much cheaper than the M112 or M90 route.
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
RWHEELS
Sep 5, 2015 03:42 PM
M3hunter
