wheel spacers? good or bad
Old Oct 2, 2005 | 04:17 AM
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: wheel spacers? good or bad
wider means more aggressive..which is not stock on our v6 stangs sad to say LOL
Old Oct 2, 2005 | 04:21 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: jj84756
yeah i don't know what i am going to do. i realy want to keep my car stock looking, just change motor and stuff. i thought using adapters would make it a little wider, but keep the stock look.
You could just go with 245 tires...and still use the stock rims.
Old Oct 2, 2005 | 12:52 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
ORIGINAL: 03YellowPony
ORIGINAL: jj84756
what he said. 245s on front and 255 on back, it works, that is what i have,
Old Oct 2, 2005 | 03:34 PM
97mustang17's Avatar
97mustang17
what do you guys think of 245 on the front and 275 on the back
Old Oct 2, 2005 | 04:16 PM
Autobadges.com
Banned
275 in the rear are aggressive...its what I have...if you have 18" tires yes...other than that it will look dumb with the tire hanging over the rim
Old Oct 2, 2005 | 08:22 PM
jj84756's Avatar
jj84756
does the 255 or whatever have to do with width?? cause i was thinking about doing this maybe.
Old Oct 2, 2005 | 08:48 PM
03YellowPony
ORIGINAL: jj84756
Yes. Ie: 245/55R15 the 245 is the width aspect, the 55 is the height, and 15 is the diameter of the rim.
Old Oct 2, 2005 | 09:06 PM
jj84756's Avatar
jj84756
ok so you are saying stock is 245?? and i should go with 255 or 265?
Old Oct 2, 2005 | 09:48 PM
03YellowPony
No I did not say stock was 245. That was just an example. My stock tires were 225/60r16. Every model has a diferent stock size. Look at the sidwall of the tires on your car. But 245's or 255's are probably the widest you want on stock rims. I intend on going with 245's all around. This is so I can rotate my tires. If you go with say 245's front and 255's rear, you don't want to rotate the tires.
Old Oct 2, 2005 | 11:59 PM
jj84756's Avatar
jj84756
oh ok i must have misunderstood. i'll look at them sometime.
