A/C from ice cold to none
Old Jun 8, 2013 | 06:21 PM
varnco's Avatar
varnco
Default A/C from ice cold to none
So, the A/C went from ice cold to almost none, and then shortly thereafter, the serpentine belt broke.
Replaced the belt, no problem.
The A/C, however, isn't working but just for a short while.
With the engine off, I get the low side pressure practically pinning the needle at max on the gauge while the high side is at about 140.
With the engine running, and the A/C running, I get this
And the clutch on the compressor goes on/off, the outer part of the compressor starts/stops and/or turns slowly...
Color of the oil (viewfinder in picture) is yellow.. is that normal?
Thoughts? Bad compressor? Bad valve somewhere?
Thanks.
Old Jun 9, 2013 | 06:29 PM
varnco's Avatar
varnco
Any thoughts?
When running at first, the compressor cuts on and off, every 10 seconds or so... one time, though, as the clutch was engaging again, I actually saw sparks fly!
Bad compressor?
Old Jun 11, 2013 | 08:14 AM
petrock's Avatar
petrock
Yeah, sounds like the compressor clutch is bad. Its probably giving a squealing noise as the belt slips overtop of it. After a while you’ll break another belt. If your handy with tools, you can replace just the clutch without having to touch the A/C lines. Otherwise, replace the entire compressor and have the A/C refilled etc. Good luck...
4cylinderplus2
Oct 9, 2020 07:45 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Explosive
Oct 2, 2015 07:45 AM
RCS02v6
Sep 29, 2015 01:46 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
