Possible electrical problems?
Old Aug 7, 2013 | 02:33 PM
IronMan0002005's Avatar
IronMan0002005
Default Possible electrical problems?
My car has been doing some funny stuff, and I have been brushing it off until recently because it is getting more noticeable. I have a V6 manual and it seems to have problems distributing power. Anything you do that uses a considerable amount of juice makes the RPM's drop and the car almost stalls out. It used to to it if I was, for example, coming around a corner in a parking lot and was coasting as I did so with the car in neutral at a low speed, when I turned the wheel and the power steering pump had to kick in you could feel the car shake. It started doing it when you would roll the windows up or down, when you brake sometimes, and now it does it every few seconds while the car idles. Just sitting at a red light in neutral, not doing anything, no movement, no windows moving, not turning the steering wheel, just every few seconds the RPM's will drop and the car will shake like it's trying not to stall. Any ideas as to what this could be?
By the way, it's a brand new alternator and battery. Changed them a month after I got the car.
Old Aug 7, 2013 | 04:13 PM
dawson1112's Avatar
dawson1112
When was the last time it had a full tune up?
Plugs, wires , air filter , fuel filter, oil change,
Old Aug 9, 2013 | 01:10 PM
Dr.Le's Avatar
Dr.Le
Sounds like a tune up issue. When i think of RPM fluctuating, i think of spark plugs, wires, and coil (b/c the car fires in order and when it comes to a 'bad' cylinder, the rpm drops and it cycles to the next cylinder.)
dont forget the MAF sensor (please use proper MAF sensor cleaner for it, if you do decide to clean it).
Old Aug 10, 2013 | 06:13 AM
IronMan0002005
the only two things I haven't changed recently were the fuel filter, and I didn't clean the maf. other than that a full tune up was done this week.
Old Aug 10, 2013 | 07:18 PM
Daehawk's Avatar
Daehawk
IAC perhaps?
Old Aug 14, 2013 | 12:59 PM
IronMan0002005
Originally Posted by Daehawk
IAC perhaps?
Perhaps, might explain my problems when I'm idling, but would that cause problems while the car is moving? I suppose it could, if the car was in neutral. That's located in the throttle body?
Old Aug 14, 2013 | 04:29 PM
Daehawk's Avatar
Daehawk
Ya it is. Might need a good cleaning. Could also be a vac leak too.
Old Aug 16, 2013 | 09:42 PM
IronMan0002005
So the "loping" at idle I was having is gone. But it seems to be worse (maybe my imagination) when you turn or when you roll the windows up or down. Any other thoughts?
Old Aug 16, 2013 | 10:21 PM
Cockygt500's Avatar
Cockygt500
O2 sensor sounds like the problem. If any of them are reading bad then it will cause all the problems your listing. Is the check engine light on?
Old Aug 19, 2013 | 03:37 PM
IronMan0002005
Check engine is on. And now the driver side window went out. -_-
