Engine Swap
Old Jan 30, 2003 | 02:20 AM
pikapp506's Avatar
pikapp506
Default Engine Swap
Will a newer model V6 work in a '94 model?
Old Feb 24, 2003 | 10:13 AM
dickbuttlover's Avatar
dickbuttlover
Default Engine Swap
Hey man you are gay why don't you buy a real f**king mustang you dick loving fagget
Old Mar 26, 2003 | 09:23 PM
hubada26's Avatar
hubada26
Default Engine Swap
sweet name their buddy
Old Mar 26, 2003 | 09:25 PM
hubada26's Avatar
hubada26
Default Engine Swap
how new are you talking. from what i under stand anything under a 98 will bolt up no problem but as for changing to 99 and newer im not so sure i hear that the chassis are the same but i engine is differnt something to do with cross manafolds
Old Mar 26, 2003 | 09:28 PM
hubada26's Avatar
hubada26
Default Engine Swap
I just swapped a 99+ engine into my 94. I had to have a new fuel rail made to add a return line to the 99 rail. I also had to switch the camshaft sensor. I also had to cut and splice the injecotor plug wires from the 99 harness to the 94, because the plugs on the injectors are different. I also had to cut and splice a few of the other sensor plugs to work with the 99 sensors I could use. I also had to lengthen some of the wires on the 94 harness cause the sensors are in different places. Also when you switch to a 99+ you need to use the 99 MAF sensor, because the 99 uses 21lb injectors and the 94 uses 14 lb injectors. I was able to use the 94 computer.
You can't use the 94 intake, because the 99's throttle body sits closer to the wall and the 94 intake is to long and will not fit.
Old Mar 26, 2003 | 09:30 PM
hubada26's Avatar
hubada26
Default Engine Swap
ask this guy hes the one i quoted above < knupxfon >
Nick Oliver
Oct 17, 2018 04:22 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
