Whats this part called
And where is a good place to get one?
Its the drivers side door panel. The plastic piece with the windows , door locks, and I think but not sure mirror controls in it. Mine is broken. 2 of the 3 clips are just gone. I hold there to close my door and now it almost just pops completely out when I close my door.
I figure it will be an easy install that I can do myself. But I dont know what the name of the part is Im looking for a good place to buy one.
I wouldn't disconnect the battery just to unplug it and replace it.
http://www.ebay.com/itm/9546C-FORD-MUSTANG-01-02-03-OEM-MASTER-POWER-WINDOW-CONTROL-SWITCH-PANEL-UNIT-/171126055841?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d7e863a1&vxp=mtr
If you pull that panel off, behind it is a screw that holds the big panel to the door. I carefully measured and marked on the switch panel where that screw was behind it and then drilled a hole just big enough for the screw. Then screwed that piece to the door. I'll get a pic when I get home. But if it's already broke it's not like your making it worse.
Are you looking for the plastic trim/handle or the window control panal (electrical part like pictured in post #3).
I think you are looking for this:
http://www.latemodelrestoration.com/...dows-And-Locks
ty
