Please help!!
Old Mar 3, 2014 | 11:55 PM
zachcoutts's Avatar
zachcoutts
Default Please help!!
No power to fuel pump. No signal from pin 5 on ccrm, all other pins good, new inertia switch, tested pump as good, fuses testes as good. No clear bad grounds, helppppp
Old Mar 13, 2014 | 09:21 AM
H1ck55ter's Avatar
H1ck55ter
i would see if the circuit is open anywhere on that wire, if your geting no power, or see if your grounding out somewhere.
Old Mar 14, 2014 | 04:24 PM
zachcoutts's Avatar
zachcoutts
Can't find any openings. Traced the wire and just put in a new inertia switch and now ccrm so I'm sure its a ground problem somewhere before ccrm but can't find it
Old Mar 16, 2014 | 09:21 PM
BabyGT's Avatar
BabyGT
Ignition switch??
Old Mar 17, 2014 | 06:26 AM
theLozano's Avatar
theLozano
An open circuit doesn't always mean a cut or torn wire. The wire may be torn internally in the wire wrapping or you may have corrosion that can't be seen. Also check the connectors for corrosion or loose pins. If no circuit issues then maybe your pcm.
