4.10's/T-Lok
Old Oct 18, 2005 | 10:00 PM
namezod's Avatar
namezod
Default RE: 4.10's/T-Lok
diferential turns only the right rear wheel.
differential turns both wheels equally when they both have traction and driving in straight line (red light launch)
but, if one tire loses traction all the torque is put on that wheel.
mustangs right side weighs less? or the way engine spins puts more weight on left wheel so right tire breaks easier?
once it breaks, all torque on right wheel
t-lok uses clutch plates to try to keep both wheels turning at same speed. t-loks bad for parking lot tight turns but good for everything else..... until they wear out.
Old Oct 18, 2005 | 10:14 PM
03YellowPony's Avatar
03YellowPony
[sm=funnypostabove.gif]
Old Oct 18, 2005 | 11:40 PM
jthorn9's Avatar
jthorn9
The Godfather
3.27 for 99-04 and a ridiculas 2.73 for the 94-98 and I think 3.55 for the 05-06s. Now that we have burried the t-lok issue 40ft deep, upgrading to larger gears will give you better accelleration, the higher the number, the better the accelleration, but be warned, the higher you go the more top speed you loose, the loss will be slight, so for road use you are ok, but hope you don't try to win a top speed competion on the track.
Old Oct 18, 2005 | 11:44 PM
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
ORIGINAL: 03YellowPony
EXACTLY...We're explaining gears, CAI's, and exhaust EVERY week!!
WHO IS OUR MOD???????????? Do we even have one??????
I nominate/.......ME!LOL
You've already got a Mod named HotRods_n_Booze, and you're one of the one's who was asking about gears himself recently.
Old Oct 18, 2005 | 11:48 PM
03YellowPony
ORIGINAL: The Great Cornholio
Yea, and I've explained them a lot too. That's why we need a sticky!
Old Oct 19, 2005 | 12:36 AM
alovell's Avatar
alovell
Also, 3.73 are the number code for the gear size in your rear end, just incase you needed gears 101.
Old Oct 19, 2005 | 10:09 AM
The Great Cornholio
I ♥ Acer
Number code? To clarify it's ring gear teeth divided by pinion gear teeth just in case you needed gears 102
Old Oct 19, 2005 | 01:45 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I wouldn't recommend gears 101 as a needed course, but gears 102 definitely helps to clarify a lot of the concepts learned in gears 101.
Old Oct 19, 2005 | 03:27 PM
Autobadges.com's Avatar
Autobadges.com
Banned
well chris needs to get his lazy butt in here to make stickies...or ask for help!!!
Old Oct 19, 2005 | 03:48 PM
HRnB's Avatar
HRnB
Administrator
I haven't made a gear sticky because we wouldn't have anything else to post about if I did. [sm=smiley36.gif]
Someone write up a good one and PM me when your done and I'll sticky it for you bishez.
