What should I buy
Old Oct 19, 2005 | 11:06 PM
Lazer Red v6's Avatar
Lazer Red v6
Default RE: What should I buy
I've heard from alot of people that you should get 3.73's for a manuel. And if i get new gears should i get a T-loc?
Old Oct 19, 2005 | 11:08 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: Lazer Red v6
DEFINATLY. From personal experience, it's tha BOMB! And if you're going for gears, they shouldn't charge much more for labor since they are gonna have to take the dif apart anyway.
Old Oct 19, 2005 | 11:10 PM
Lazer Red v6
So what would be better 3.73's or 4.10's?
Old Oct 19, 2005 | 11:15 PM
03YellowPony
Generally, it's like this. Manual's 3.73's. Auto's 4.10's. But again, it's up to you. But I do HIGHLY recommend the T-Lok either way you go.
Old Oct 19, 2005 | 11:19 PM
Lazer Red v6
Why different size for different drive train?
Old Oct 19, 2005 | 11:22 PM
03YellowPony
It has to do with the transmission gear ratios. Not sure exactly what it is, but I think it's cus the manual has a higher ratio.
Old Oct 19, 2005 | 11:52 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Im am selling my current car to a kid I know for 7,500. Its a 96 V-6 with 73thousand miles.
I want to get a 99 or 2000 V-6. What do u guys think i should get?
99 GT!
Old Oct 19, 2005 | 11:56 PM
tightdogal's Avatar
tightdogal
nanaki on here has a manual and he put on 3.73's....he regrets not getting the 4.10's......so im pretty sure if ur a manual, ud want 4.10's as well.
Old Oct 20, 2005 | 02:16 AM
jthorn9's Avatar
jthorn9
The Godfather
Yea gears are a good first mod to go with. Now I'll give you some shopping advice to help you get the best deal possible. Go to msn.com, then select on the autos area. Select Ford, then mustang. Pick any year, then scroll down to the bottom and look up the listings in your area by typing in your zip code. It will give you most of the used mustang listings for your area, you can do an advanced search to look up a specific year, widen your range, or set price caps. Go check them out.
Old Oct 20, 2005 | 03:57 AM
03YellowPony
Or better yet. Use our sponsors. I looked for gears and a T-lok for weeks. Then I asked AutoBadges. He sent me to www.stangsuspension.com . They had the best prices I found. $199.00 for the gears, and $199.00 for the T-lok. AND if you use the discount code 38STANG, you get 5% off.
Edit...
Don't forget the friction modifier, also at stangsuspension, and the Royal Purple dif fluid!
