Replacing Fuel Fill Grommet
I have a 99 V6 Base Mustang Convertible, and noticed fuel leaking after I fill up. It's without a doubt the Grommet that seals the fill tube.
I am ready to replace it but am getting two different methods.
One shows dropping the tank, the other shows removing the fill tube without dropping the tank.
Anyone have a preference, which would be easier?
Thanks
Thanks
I wasn't aware it could be done without dropping the tank. Sounds like an attractive idea, but I'm not sure how much room it's going to give you to work. I replaced mine a couple years ago, and lowered the tank to do it. Make sure to smear some petroleum jelly (Vaseline) one the new grommet so it'll slip right in.
I replaced mine in the 96. I did not drop the tank to do it. I did loosen the tank straps on the filler side and removed all bolts holding the filler neck in place.
to reinstall, i put the gasket on the filler neck first and then once i had the neck in the tank i pushed the gasket into place.
With a decent set of jack stands under the axle you have more than enough room to drop the tank, I just did this when I had to replace my fuel pump, and mine is lowered. A second set of hands helps tremendously.
