brake problem
Old Nov 12, 2015 | 10:35 AM
col2560's Avatar
col2560
Default brake problem
I have a problem with my brakes. when I push the pedal down, it feels like the 1st half of the travel has only a little feel, then it firms up if I push harder. as I understand the system, pressure goes to the rear brakes first, then as the pressure rises it goes to the front brakes. there are no warning lights on the dash.
thanks.
Old Nov 12, 2015 | 11:20 AM
PNYXPRESS's Avatar
PNYXPRESS
Fronts brake first then rear. you either need new pads or have air in the lines.
Old Nov 12, 2015 | 07:05 PM
col2560's Avatar
col2560
pads are all good and I bled all corners, it doesn't feel spongy like air in the lines, more like too much pedal free travel. I just replaced the driver side caliper, it was rusted solid so hasn't been working for some time.
Old Nov 13, 2015 | 10:54 AM
col2560's Avatar
col2560
ok today I pulled the wheel off again and had my wife pump the pedal. it was the piston retracting after the pedal was released, so just too much travel on the piston. I pulled the caliper off and wound it out 1/2 a turn and now it's all good, almost put me through the windshield..
I never had the piston do that before, they always stay out, just off the disc, this one looked like there was a spring pulling it back in. beats me....
Old Nov 13, 2015 | 10:57 AM
col2560's Avatar
col2560
checked my repair manual today, and it says that the back brakes come on first, I could feel it when I was bleeding the brakes, with the bleeder backed off the pedal was easy until it reached where the front brakes were in the pedal travel, then it got hard again because the front bleeder is closed.
Old Nov 13, 2015 | 12:55 PM
PNYXPRESS's Avatar
PNYXPRESS
You manual is wrong. If the rears brake first then you wouldnt be able to do a burnout while using the brakes to hold the front wheels from turning.
Im not sure what is up with your rear calipers though as the pistons shouldnt screw out.
Fabian999
Nov 15, 2015 11:50 PM
05BlackPony
Nov 14, 2015 06:55 PM
jordan20523
SVT Forums
Nov 10, 2015 01:04 PM
Webster454
Nov 9, 2015 07:40 PM
BigDaddy0363
Nov 9, 2015 05:39 PM
