ignition problem
Old Feb 1, 2016 | 12:26 AM
col2560's Avatar
col2560
Default ignition problem
went to start my car the other day and things went crazy, all the needles on the gauges started spinning back and forth, warning lights were flashing and the trip meter reset to zero. also, starter wouldn't crank, it was like the scene from close encounters. any ideas?
After a few tries the car did start and ran just fine.
thanks.
Old Feb 1, 2016 | 08:59 AM
PNYXPRESS's Avatar
PNYXPRESS
Sounds like you need a new battery.
Old Feb 1, 2016 | 09:02 AM
col2560's Avatar
col2560
but now it's cranking fine, is there a connector in the steering column that can come loose?
Old Feb 1, 2016 | 09:53 AM
PNYXPRESS's Avatar
PNYXPRESS
Check your battery cables then. The gauge issue sounds like a low or no voltage issue
Old Feb 1, 2016 | 11:56 AM
Daehawk's Avatar
Daehawk
Sounds like a loose cable on the battery.
Old Feb 2, 2016 | 01:10 PM
col2560's Avatar
col2560
cleaned both battery connectors today, see how it goes
Old Feb 22, 2016 | 01:18 AM
col2560's Avatar
col2560
no problems since I cleaned everything, phew. inside the terminal clamps looked like black paint, came right off with some sandpaper.
Natasha Spizelli
Feb 21, 2016 03:04 PM
Mustanggirl719
Jan 13, 2016 08:48 AM
Nando.
Jan 12, 2016 01:08 AM
