Rear wheel hub assemblys
Old Sep 19, 2016 | 10:59 PM
Matthew954's Avatar
Matthew954
Default Rear wheel hub assemblys
Where do I find rear end wheel hubs and bearings? I think the rear passenger bearing is going bad on my 2004 sixer, but everywhere I go to find the whole hub, I only find front. So I'm assuming there isn't an actual hub, just the bearing?
Old Sep 20, 2016 | 08:44 AM
proeagles's Avatar
proeagles
Correct, pull the axles, fun.
Old Sep 20, 2016 | 09:48 AM
jwog666's Avatar
jwog666
you have a solid read axle. tires, brakes, diff cover, and axle shafts all have to come out to change the bearings. but.....the noise you are hearing could be those bearings, or the differential bearings, or even the gears making noise.
Old Sep 20, 2016 | 10:36 AM
Matthew954's Avatar
Matthew954
I'm also feeling some vibration in the rear. I can feel it through the seat, and the steering wheel as a sort of mild shudder. I attributed it to the bearings, when I changed the rear brakes in the spring. There was some minute play in the wheels.
I'm pretty much guessing this isn't going to be an easy fix.
Old Sep 20, 2016 | 01:32 PM
jwog666's Avatar
jwog666
if you feel a vibration in the steering wheel the tire balance is most likely the issue
adam1997gipe
Wheels & Tires
Oct 19, 2016 08:36 AM
96t-bird
Sep 22, 2016 09:34 AM
pavesema
Sep 19, 2016 02:18 PM
C1Forged
Sep 16, 2016 05:38 PM
NeoGeo630
Sep 14, 2016 12:25 PM
