weight????
Old Oct 27, 2005 | 03:01 PM
jj84756's Avatar
jj84756
Default weight????
does anybody know the stock weight of an 02 v6 mustang? i looked for it online and couldn't find it, but i'm sure i just overlooked it.
Old Oct 27, 2005 | 03:05 PM
976stangmod's Avatar
976stangmod
Default RE: weight????
i thin its aroun 3000 maybe 3100 not much more then that the convt. weigh alot more
Old Oct 27, 2005 | 03:26 PM
Jimmz's Avatar
Jimmz
Yeah its 3200 lbs. the verts weigh close to 3500+
Old Oct 27, 2005 | 03:32 PM
TattooTears's Avatar
TattooTears
I just tried to look it up and could only find it in kg with was 1391 kg. So if you know the converstion you can figure it out, but I'm not sure what 1kg is equal to in lbs.
Old Oct 27, 2005 | 04:49 PM
99Stang_V6's Avatar
99Stang_V6
well...if there is 454 grams in a pound...convert 1391 kg to grams...then use the conversion...here ill do it for ya....
it is around 3064 lbs....rounding off of course
1391x1000=1391000/454= 3063.whatever the numbers are
Old Oct 27, 2005 | 05:10 PM
jj84756's Avatar
jj84756
alright thanks. i was using that program that tells your quarter mile times depening on h.p. and weight and didn't know what the weight was.
Old Oct 27, 2005 | 05:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 99Stang_V6
or use 2.2Kg per pound soooo....1391X2.2 = 3060.2
Old Oct 27, 2005 | 06:34 PM
HRnB's Avatar
HRnB
Administrator
I just looked at mine on the drivers side door jam. 03 vert
GVWR = 4365lbs
Front GVWR = 2306lbs
Rear GVWR = 2117lbs
[sm=smiley3.gif]
Old Oct 27, 2005 | 06:37 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: HotRods_n_Booze
GVWR = 4365lbs
Rear GVWR = 2117lbs
[sm=smiley3.gif]
Ummmm Booze..that's the total weight the vehicle can be. Including ppl, and luggage/cargo. Not "Dry Weight".
GVWR= Gross Vehicle Weight Rating....
Old Oct 27, 2005 | 06:52 PM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: 03YellowPony
GVWR = 4365lbs
Rear GVWR = 2117lbs
[sm=smiley3.gif]
*SHWEW* Thanks, I was thinking, WTF!
So I can take the passenger weight and subtract it from the GVWR and get my weight?
