Car won't start, service engine light is not on
Old Nov 7, 2017 | 11:54 AM
Urambo Tauro's Avatar
Urambo Tauro
Maybe. You did mention that starting fluid seemed to help, so there could still be a problem with fuel delivery.
So you've got pressure up to the fuel rail... are the injectors spraying?
Old Nov 7, 2017 | 01:36 PM
ddub07's Avatar
ddub07
How can I check?
Old Nov 7, 2017 | 02:20 PM
Urambo Tauro
You can look for power being sent to the injectors while cranking, and/or disable the ignition and see if the spark plugs are wet after cranking.
Old Nov 7, 2017 | 04:34 PM
ddub07's Avatar
ddub07
How do I disable ignition? I'm working by myself and can't crank and watch meter at same time.
Old Nov 8, 2017 | 10:24 AM
Urambo Tauro
Any way you want, really. CKP sensor, ICM, coil, plug wires... all you have to do is keep the plugs from sparking, so they won't burn off any fuel that gets sprayed.
Old Nov 8, 2017 | 11:15 AM
ddub07's Avatar
ddub07
Disconnecting the coil plug, won't effect the injectors spaying?
Old Nov 8, 2017 | 11:33 AM
Urambo Tauro
Hm, I think it's the CMP sensor that controls fuel delivery.
