Ported Intake?
Old Oct 29, 2005 | 09:29 PM
HRnB's Avatar
HRnB
Administrator
Default RE: Ported Intake?
ORIGINAL: redass02gt
ORIGINAL: ByPopularDemand
So you can polish the intake too
actually, you can only Polish it.
Not true. Extrude honing is a highly recommended way of doing a split port.
Old Oct 29, 2005 | 09:33 PM
ByPopularDemand's Avatar
ByPopularDemand
ORIGINAL: HotRods_n_Booze
Do you mean the intake or the heads?
Old Oct 29, 2005 | 10:04 PM
HRnB's Avatar
HRnB
Administrator
intake
edit: I should add that it is polishing, but it is also opening the ports up too.
Old Oct 30, 2005 | 01:33 AM
Autobadges.com's Avatar
Autobadges.com
Banned
hopefully they gave you all the info you were looking for.
Porting is opening up a tube...say from the size of a coffee straw to that of a McDonalds straw...its bigger and flows better. If you polish it....its super smooth so nooooooooo turbulance on the air and it flows BETTER.
Old Oct 30, 2005 | 11:46 AM
matthockey32's Avatar
matthockey32
I ♥ Acer
doing a good P&P job on the intake and heads is a good way to add power to a split-port. i have personally ported a few uppers for some people. just by port-matching you can pick up 10 rwhp. i know, i've seen me do it.
ByPopularDemand
Yep I got it now I know how the whole TB thing should work without loosing power
Old Oct 30, 2005 | 05:09 PM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: matthockey32
So you do your P&P's in front of a mirror.
Hey Matt, did you just use a honing tool like for cylinders and just go to town on the thing, or did you use a micrometer and get a specific size? Just curious.
Old Oct 30, 2005 | 07:07 PM
matthockey32
I ♥ Acer
40,000 rpm die grinder and self calibrating micrometer. all are within 0.0001 of an inch apart. at least on my car. just the upper. the lower is just port matched to the heads and upper.
Old Oct 30, 2005 | 07:19 PM
03YellowPony's Avatar
03YellowPony
<wondering how long it's gonna take me to port the intake out to 70mm with a Dremmel......
Old Oct 30, 2005 | 07:57 PM
matthockey32
I ♥ Acer
bout an hour
