2004 mustang overheating
Old Jul 19, 2022 | 10:06 AM
Froyo2343234's Avatar
Froyo2343234
Default 2004 mustang overheating
So I got this 2004 mustang during the winter it runs smoothly but in the summer it stalls on a hot day when I use my ac but it doesn't stall Immediately it takes About an hour after the ac is on. it sputter out and turns off and i wait about 2 hours then i can get back in a run smoothly without the ac on the temp is normal on the dash also?
Old Jul 19, 2022 | 10:59 AM
NYstang's Avatar
NYstang
MF Staff Snitch
How is the idle? Does it drop? May be the IAC (Idle air control) valve
JamesBenedict's Avatar
JamesBenedict
Is temp gauge rising to hot with AC use? If so, likely the radiator is partly plugged.
Old Jul 19, 2022 | 11:14 AM
Froyo2343234
The idle is fine till the problem happens then it bogs down till it stalls and the tem gage stays in operating range
Old Jul 19, 2022 | 11:16 AM
JamesBenedict
Other issue, not overheating.
Froyo2343234
While I'm driving And I push in the gas I get no power also
Old Jul 19, 2022 | 11:17 AM
Froyo2343234
I let it sit for a couple hours and then it drive fine again
JamesBenedict
You should be getting an engine code that will tell you the issue.
Old Jul 19, 2022 | 11:19 AM
Froyo2343234
The only code I have is for the cats
Old Jul 19, 2022 | 11:22 AM
JamesBenedict
Unusual, I am stumped. Take car to a Ford dealer. I also have a 2004 Mustang and is a convertible.
